Electrical specification:
Mechanical specification:
Package contents:
The Loco deck, microSD and Flow (v2) deck all uses the SPI bus. As the BigQuad deck uses the deck SPI buss pins for possible voltage and current measurement, as they are multiplexed with analog input, the BigQuad deck is not compatible with these decks.
CFLAGS += -DENABLE_BQ_DECK
