Electrical specification:
Mechanical specification:
Package contents:
The Loco deck, microSD and Flow (v2) deck all uses the SPI bus. As the BigQuad deck uses the deck SPI buss pins for possible voltage and current measurement, they are multiplexed with analog input, the BigQuad deck is not out-of-the-box compatible with these decks. This can fixed:
Capacitor C1 is used to filter the current measurement and removing this has the effect that it will not be filtered any more. Still possible to use it if a deck using the SPI is not wanted any more.
Next problem is how to mount the deck in a nice way on the quad, I leave that up to you.
CFLAGS += -DENABLE_BQ_DECK
