Electrical specification:
Mechanical specification:
Package contents:
The Loco deck, microSD and Flow (v2) deck all uses the SPI bus. As the BigQuad deck uses the deck SPI buss pins for possible voltage and current measurement, and they are multiplexed with analog input, the BigQuad deck is not out-of-the-box compatible with these decks. This can fixed:
Capacitor C1 is used to filter the current measurement and removing this has the effect that it will not be filtered any more. Still possible to use it if a deck using the SPI is not wanted any more.
To make it work with the Flow (v2) deck more changes/patching are needed.
Next problem is how to mount the deck in a nice way on the quad, we leave that up to you.
Currently there is only a basic setup but as the development advances so will the documentation. Start by mounting the big quad deck on the frame. After that connect the ESCs according to the diagrams below. Note that the 5V is needed for the motor signals and in not optional.
CFLAGS += -DENABLE_BQ_DECK
