The LED ring expansion deck contains two powerful front-facing white LEDs and 12 bottom-facing RGB individually addressable LEDs (it uses the same LEDs as used in the NeoPixel products by Adafruit).
The RGB LEDs are connected in in series and can be addressed individually. When a new color is sent to U1, the U1 color is sent to U2, the U2 to U3 and so on. So sending 12 colors to U1 will update the full ring. Drivers for the ring exist in the Crazyflie 2.0 firmware.
Led ring expansion deck schematic.
| Name | Type | Access | Value (default) | Description |
| ring.effect | uint8_t | RW | 6 | Ring effect (0=off, 1=White spinner, 2=Color spinner, 3=Tilt effect, 4=Brightness effect, 5=Color spinner2, 6=Double spinner, 7=Solid color effect, 8=Factory test, 9=Battery status, 10=Boat lights, 11=Alert, 12=Gravity, 13=N/A) |
| ring.emptyCharge | float | RW | 3.099.. | |
| ring.fullCharge | float | RW | 4.199.. | |
| ring.glowstep | float | RW | 0.050.. | |
| ring.headlightEnable | uint8_t | RW | 0 | Headlight LEDs (0=off, 1=on) |
| ring.neffect | uint32_t | RO | 13 | Number of available ring effects |
| ring.solidBlue | uint8_t | RW | 20 | |
| ring.solidGreen | uint8_t | RW | 20 | |
| ring.solidRed | uint8_t | RW | 20 |
