projects:crazyflie2:expansionboards:microsd
micro-SD expansion deck
Adds the possibility to read and write files to a micro SD card.
Specification
  • micro-SD card socket connected in SPI mode.
  • Mechanical specification:
    • Weight: 1.7g
    • Size (WxHxD): 21x28x4mm
Schematic
micro-SD expansion deck schematic
Filesystem
We use FatFS as the file system handler. Have a look at the API and examples on the FatFS site fore usage information.
The FatFS module will be initialized by the micro-SD deck driver when the deck is detected. After that the API calls can be used such as f_mount, f_open, f_read, f_close etc.
projects/crazyflie2/expansionboards/microsd.1485344807.txt.gz · Last modified: 2017-01-25 12:46 by tobias
