projects:crazyflie2:expansionboards:qi
This page has deprecated and moved to the new documentation framework of the main Bitcraze website. Please go to https://www.bitcraze.io/ and go to the menu 'products'.
Qi Wireless charging expansion deck
The Qi wireless charging expansion deck allows charging the Crazyflie 2.0 battery with a standard Qi wireless charger. The deck is designed to provide up to 1A which means that the charging speed should be equivalent to USB charging. Using a wireless charger is convenient (just put the Crazyflie on the charger and pick it up later once charged) but mostly it allows new and interesting use cases such as autonomously landing on the charger to enable an extended autonomous flight system.
This expansion deck has very few Crazyflie 2.0-specific components, so it can still be used as a wireless 5V power supply for other projects.
The deck works by injecting 5V into the Crazyflie 2.0 VUSB line. As a consequence, it is not recommended to connect the Crazyflie to a 5V USB charger while the Qi expansion deck is installed. Furthermore, do not connect a USB charger while a Qi-equipped Crazyflie 2.0 is sitting on a wireless charger.
Specification
  • Based on the TI BQ51013B
  • Can supply up to 1A at 5V
  • Supports the Qi wireless charging standard (WPC V1.1)
  • Mechanical specification:
    • Weight: 5.0g
    • Size (WxHxD): 30x30x5mm
Charger compatibility
The Qi wireless charger expansion deck works with WPC 1.1 compatible charger pads.
Schematic
Qi expansion deck schematic.
projects/crazyflie2/expansionboards/qi.txt · Last modified: 2021-06-24 14:10 by kimberly
