projects:crazyflie2:expansionboards:zranger-v2
Z-ranger v2 deck
Adds the possibility to fly with precise height control. Using the ToF sensor VL53L1x the Crazyflie 2.0 can measure the distance from the sensor to a ground object at up 4 meters.
Specification
  • VL53L1x ToF sensor to measure distance up to 4 meters.
  • Mechanical specification:
    • Weight: 1.6g
    • Size (WxHxD): 21x28x4mm
Schematic
Z-ranger v2 deck schematic
Default usage
To get started you can follow the Z-Ranger getting started guide.
The Z-ranger deck will be automatically detected when it is mounted. By default the range is available on the log variable “range.zrange” and is used instead of the pressure by internal algorithms.
The best way to use the Z-Ranger deck is to enable the Height-hold mode in the client. This requires at least client and firmware 2017.04 so make sure to update your Crazyflie.
Usage with the experimental Kalman filter
The Kalman filter is a sensor fusion algorithm that is still experimental. You can try it by recompiling the Crazyflie firmware.
To enable altitude control using the Z-ranger with the kalman filter, the Crazyflie firmware has to be recompiled with the following config.mk:
config.mk
ESTIMATOR=kalman
CFLAGS += -DUPDATE_KALMAN_WITH_RANGING -DKALMAN_DECOUPLE_XY
The sensor can measure distances up to 4 meters but often fails at distances above 3m. In case of unreliable readings the Crazyflie 2.0 will slowly drift. If that happens bring it down to the detection range.
projects/crazyflie2/expansionboards/zranger-v2.1540210444.txt.gz · Last modified: 2018-10-22 14:14 by tobias
