skip to content
Bitcraze Wiki
Log In
Search
Tools
Show pagesource
Old revisions
Backlinks
Recent Changes
Media Manager
Sitemap
Log In
Recent Changes
Media Manager
Sitemap
You are here:
index
projects
crazyflie2
hardware
specification
Trace:
userguide
Sidebar
Crazyflie 1.0
Crazyflie 2.X
Crazyflie Bolt
Expansion decks
LED-ring
Buzzer
BigQuad
Qi charging
Qi 1.2 charging
Prototype
Breakout
Micro-SD
Bosch Sensors
Z-ranger
Z-ranger v2
Loco deck
Flow deck
Flow v2
Multi-ranger
Lighthouse
MoCap marker
Active marker
AI-deck
Crazyradio
Crazyradio PA
Loco Positioning
Node
Deck
Roadrunner
Accessories
Li-Po charger
Breakout boards
Flow breakout
Bitcraze VM
The toolbelt and Docker Builder Images
Documentation
Crazyflie
Crazyradio
PC client
Loco Positioning System
Lighthouse positioning
Misc
Downloads
Builds/hacks/HOW-TOs
Investigations
Windows USB driver
About the wiki
projects:crazyflie2:hardware:specification
Crazyflie 2.0 hardware specification
Mechanical specification
Weight: 27g
Size (WxHxD): 92x92x29mm (motor-to-motor and including motor mount feet)
Radio specification
20 dBm radio amplifier tested to > 1 km range LOS with Crazyradio PA
Bluetooth Low Energy support with iOS and Android clients available (tested on iOS 7.1+ and Android 4.4+)
Radio backwards compatible with original Crazyflie and Crazyradio
Micro-controllers
STM32F405 main application MCU (Cortex-M4, 168MHz, 192kb SRAM, 1Mb flash)
nRF51822 radio and power management MCU (Cortex-M0, 32Mhz, 16kb SRAM, 128kb flash)
uUSB connector
On-board LiPo charger with 100mA, 500mA and 980mA modes available
Full speed USB device interface
Partial USB OTG capability (USB OTG present but no 5V output)
IMU
3 axis gyro (MPU-9250)
3 axis accelerometer (MPU-9250)
3 axis magnetometer (MPU-9250)
High precision pressure sensor (LPS25H)
Flight specification
Flight time with stock battery: 7 minutes
Chraging time with stock battery: 40 minutes
Max recommended payload weight: 15 g
Expansion connector with
VCC (3.0V, max 100mA)
GND
VCOM (unregulated VBAT or VUSB, max 1A)
VUSB (both for input and output)
I2C (400kHz)
SPI
2 x UART
4 x GPIO/CS for SPI
1-wire bus for expansion identification
2 x GPIO connected to nRF51
8KB EEPROM
projects/crazyflie2/hardware/specification.1436970671.txt.gz
· Last modified: 2015-07-15 16:31 by
127.0.0.1
Page Tools
Show pagesource
Old revisions
Backlinks
Back to top
