LED 1 : Red/green LED used for heartbeat and low-battery indication
LED 2 : Blue LED fully lit when powered and blinking when bootloading
LED 3 : Blue LED fully lit when powered and blinking when charging
LED 4 : Red/green LED used to indicate radio communication
Right expansion connector : The expansion port is used to connect expansion boards, either on the top and/or the bottom
Left expansion connector : The expansion port is used to connect expansion boards, either on the top and/or the bottom
Expansion board orientation indicator : This indicator should match the expansion boards
User button : Push button used to power on/off the system. Hold down 3s while powering on to enter bootloader mode. Hold down 10s while powering to enter STM32F4 DFU mode.
nRF51822 : The nRF51822 micro controller
Mounting holes: Can be used for mechanically mounting something to the platform. The holes are plated, can be grounded by soldering a bridge and are 2mm in diameter (with plating)
Bottom
M1 connector : Motor 1 connector
M2 connector : Motor 2 connector
M3 connector : Motor 3 connector
M4 connector : Motor 4 connector
STM32F405 debug connector : Connector for debugging the STM32F405 using SWD. For easy access use our debug adapter kit.
nRF51822 debug pads : Pads for debugging the nRF51822 using SWD. For easy access use our debug adapter kit.
STM32F405 micro controller : The STM32F405 micro controller
projects/crazyflie2/userguide/index.1567686388.txt.gz · Last modified: 2019-09-05 14:26 by kimberly
