We haven't removed anything from the image, just added our own stuff. So you can still log in and used the Raspberry Pi as you would with the Raspbian Wheezy image, but as an added feature you can also use our stuff.
Let's create a user named bitcraze with the password crazyflie and add it to all the user groups.
sudo useradd bitcraze -p crazyflie -G adm,dialout,cdrom,sudo,audio,video,plugdev,games,users,netdev,input
Now install everything that we might need fro running the Crazyradio, controllers and the headless client.
sudo apt-get -y install mercurial python2.7 python-usb python-pygame xboxdrv
The shebang in the cfheadless client uses /usr/bin/pyton2 which isn't available in the original image so create a symbolic link for it.
cd /usr/bin sudo ln -s python2.7 python2
