We haven't removed anything from the image, just added our own stuff. So you can still log in and used the Raspberry Pi as you would with the Raspbian Wheezy image, but as an added feature you can also use our stuff.
Most of these commands require root user, so switch to root:
sudo su
Let's create a user named bitcraze with the password crazyflie and add it to all the user groups.
useradd bitcraze -m -p crazyflie -G adm,dialout,cdrom,sudo,audio,video,plugdev,games,users,netdev,input
Now install everything that we might need fro running the Crazyradio, controllers and the headless client.
apt-get -y install mercurial python2.7 python-usb python-pygame xboxdrv
The shebang in the cfheadless client uses /usr/bin/pyton2 which isn't available in the original image so create a symbolic link for it.
cd /usr/bin ln -s python2.7 python2
touch /etc/udev/rules.d/99-crazyflie.rules nano /etc/udev/rules.d/99-crazyflie.rules
Add xbox:
mkdir /root/bin/ touch /root/bin/cfheadless nano /root/bin/cfheadless
And add the following text:
#!/bin/sh
if test "$ACTION" = "add"
then
/usr/bin/sudo -u bitcraze /home/bitcraze/start_cfheadless &
echo $! > /tmp/cfheadless.pid
else
killall -9 cfheadless
then
PID=`cat /tmp/cfheadless.pid`
kill -9 $PID
fi
fi
#!/bin/sh
then
/usr/bin/xboxdrv &
else
killall -9 xboxdrv
fi
Now switch to the newly created bitcraze user by first exiting switching back to the pi user and then bitcraze:
exit sudo su bitcraze
cd mkdir projects cd projects hg clone https://bitbucket.org/bitcraze/crazyflie-pc-client hg clone https://bitbucket.org/bitcraze/crazyradio-firmware
echo PS3_Mode_1 > /home/bitcraze/controller.conf echo radio://0/10/250K > /home/bitcraze/link.conf
touch start_cfheadless chmod +x start_cfheadless nano start_cfheadless
/home/bitcraze/projects/crazyflie-pc-client/bin/cfheadless -u `cat /home/bitcraze/link.conf` -i `cat /home/bitcraze/controller.conf` > /tmp/cfheadless.log 2>&1
