Most of these commands require root user, so switch to root:
sudo su
Let's create a user named bitcraze with the password crazyflie and add it to all the user groups.
useradd bitcraze -m -p crazyflie -G adm,dialout,cdrom,sudo,audio,video,plugdev,games,users,netdev,input
Now install everything that we might need fro running the Crazyradio, controllers and the headless client.
apt-get -y install mercurial python2.7 python-usb python-pygame xboxdrv
The shebang in the cfheadless client uses /usr/bin/pyton2 which isn't available in the original image so create a symbolic link for it.
cd /usr/bin ln -s python2.7 python2
touch /etc/udev/rules.d/99-crazyflie.rules nano /etc/udev/rules.d/99-crazyflie.rules
In order for the Xbox 360 wireless controller to work the xboxdrv utility has to be installed and launched when the controller is connected. So add a new udev rule for this.
touch /etc/udev/rules.d/99-xboxdrv.rules nano /etc/udev/rules.d/99-xboxdrv.rules
Put the following into the text file:
mkdir /root/bin/ touch /root/bin/cfheadless chmod +x /root/bin/cfheadless nano /root/bin/cfheadless
And add the following text:
#!/bin/sh
if test "$ACTION" = "add"
then
/usr/bin/sudo -u bitcraze /home/bitcraze/start_cfheadless &
echo $! > /tmp/cfheadless.pid
else
killall -9 cfheadless
then
PID=`cat /tmp/cfheadless.pid`
kill -9 $PID
fi
fi
touch /root/bin/xbox360 chmod +x /root/bin/xbox360 nano /root/bin/xbox360
#!/bin/sh
then
/usr/bin/xboxdrv &
else
killall -9 xboxdrv
fi
Now we are finished with the system setup so switch to the newly created bitcraze user by first exiting switching back to the pi user and then bitcraze:
exit sudo su bitcraze
Go to the bitcraze users home directory and clone the PC client and Crazyradio firmware projects.
cd mkdir projects cd projects hg clone https://bitbucket.org/bitcraze/crazyflie-pc-client hg clone https://bitbucket.org/bitcraze/crazyradio-firmware
Create the script that will execute when the Crazyradio is inserted. This will launch the cfheadless client.
touch start_cfheadless chmod +x start_cfheadless nano start_cfheadless
Insert the following text into the file:
/home/bitcraze/projects/crazyflie-pc-client/bin/cfheadless -u `cat /home/bitcraze/link.conf` -i `cat /home/bitcraze/controller.conf` > /tmp/cfheadless.log 2>&1
Now the last part, the configuration. The script above will launch the cfheadless client with the controller and link configuration that is written in the two files 'controller.conf' and 'link.conf'. This configuration is written using the following commands:
echo PS3_Mode_1 > /home/bitcraze/controller.conf echo radio://0/10/250K > /home/bitcraze/link.conf
If you are using another controller configuration or another link, just use the same commands as above but replace it with your own settings.
That's it! Now you can connect the controller, start the Crazyflie and insert the Crazyradio and you are ready to fly.
