projects:crazyflie:binaries:raspberrypi
Bitcraze Raspberry Pi SD-card image
Download
The SD-card image can be downloaded here:
  • Bitcraze Raspian image 0.1 torrent (preferred)
  • Bitcraze Raspian image 0.1 direct download (limited to 6 simultaneous downloads)
SD-image info
User: bitcraze
Pass: crazyflie
What's added to the image
  • UDEV rules for access to the Crazyradio and NRF bootloader
  • crazyflie-pc-client and crazyradio-firmware pre-cloned
  • pyusb and pygame
  • UDEV rules to automatically launch the cfheadless client when Crazyradio is plugged in
  • Driver for the Xbox 360 wireless controller and automatic start of the utilities
  • Mercurial
Creating the SD-card
How to use the SD-card image
Troubleshooting
projects/crazyflie/binaries/raspberrypi.1373292965.txt.gz · Last modified: 2015-07-15 16:30 (external edit)
