The SD-card image can be downloaded here:
Size: 2 GB User: bitcraze Pass: crazyflie
You will have to edit the /root/bin/xbox file to contain the following to get the RedOctaine xbox360 (1430:f801) controller to work:
#!/bin/sh if test "$ACTION" = "add" then /usr/bin/xboxdrv --device-by-id 1430:f801 --type xbox360 --axismap X2=X1,Y2=Y1,X1=X2,Y1=Y2 & else killall -9 xboxdrv fi
