The SD-card image can be downloaded here:
Size: 2 GB User: bitcraze Pass: crazyflie
When you start your Pi the display shows the output from each of the start-up scripts (as lots of scrolling text). If starting for the first time using a new image you are logged in as a root user, and the raspi-config menu will then appear. It can also be started at any time from the command line or from a terminal window (see below).
It has the following entries (this is the layout from the Raspian 2012-12-16 image. It may be different on other images):
Raspi-config
info Information about this tool
expand_rootfs Expand root partition to fill SD card
overscan Change overscan
configure_keyboard Set keyboard layout
change_pass Change password for 'pi' user
change_locale Set locale
change_timezone Set timezone
memory_split Change memory split
ssh Enable or disable ssh server
boot_behaviour Start desktop on boot?
update Try to upgrade raspi-config
<Select> <Finish>
Select the expand_rootfs option and follow the onscreen instructions. After a reboot of the Pi, your available disk space will be maximized to the actual size of the SD card (4GB, 8GB, 16GB, etc.).
You will have to edit the /root/bin/xbox file to contain the following to get the RedOctaine xbox360 (1430:f801) controller to work:
#!/bin/sh if test "$ACTION" = "add" then /usr/bin/xboxdrv --device-by-id 1430:f801 --type xbox360 --axismap X2=X1,Y2=Y1,X1=X2,Y1=Y2 & else killall -9 xboxdrv fi
