The SD-card image can be downloaded here:
Size: 2 GB User: bitcraze Pass: crazyflie
When you start your Pi the display shows the output from each of the start-up scripts (as lots of scrolling text). If starting for the first time using a new image you are logged in as a root user, and the raspi-config menu will then appear. It can also be started at any time from the command line or from a terminal window (see below).
It has the following entries (this is the layout from the Raspian 2012-12-16 image. It may be different on other images):
Raspi-config
info Information about this tool
expand_rootfs Expand root partition to fill SD card
overscan Change overscan
configure_keyboard Set keyboard layout
change_pass Change password for 'pi' user
change_locale Set locale
change_timezone Set timezone
memory_split Change memory split
ssh Enable or disable ssh server
boot_behaviour Start desktop on boot?
update Try to upgrade raspi-config
<Select> <Finish>
Select the expand_rootfs option and follow the onscreen instructions. After a reboot of the Pi, your available disk space will be maximized to the actual size of the SD card (4GB, 8GB, 16GB, etc.).
Once your Pi is running, at the command prompt, be sure to update to the latest version:
sudo apt-get update
You will have to edit the /root/bin/xbox file to contain the following to get the RedOctaine xbox360 (1430:f801) controller to work:
#!/bin/sh if test "$ACTION" = "add" then /usr/bin/xboxdrv --device-by-id 1430:f801 --type xbox360 --axismap X2=X1,Y2=Y1,X1=X2,Y1=Y2 & else killall -9 xboxdrv fi
