projects:crazyflie:binaries:raspberrypi
Bitcraze Raspberry Pi SD-card image
In order to make it easy for users that have a Raspberry Pi to test out our headless client we prepared an SD-card image that is ready to use out of the box. The image is based on the Raspbian distribution. The image version 2015.3 is based on Raspbian version 2015-02-16 available on the RaspberryPi website.
We haven't removed anything from the image, just added our own stuff. So you can still log in and used the Raspberry Pi as you would with the Raspbian image, but as an added feature you can also use our stuff. If you would like to re-create the SD-image with your own Wheezy image then have a look at what we did.
Download
The SD-card image can be downloaded here (version 2015.3 and onward is compatible with Raspberrypi 2):
Note Using Torrent is advised, we have added webseed so it is faster than direct download and guarantee the file integrity.
Installing in an existing Raspbian sdcard
If you already have a running raspbian system no need to download the image, connect your raspberrypi and run the following command to install all packages and dependencies. We are generating the official that way. You must be logged with the 'pi' user to launch the command:
curl https://raw.githubusercontent.com/bitcraze/bitcraze-raspberry-pi/2015.3/bitcraze_raspberrypi.sh | sh
SD-image info
User: pi
Pass: raspberry
(version before 2015.3 had bitcraze/crazyflie as username/password)
What's added to the image
  • UDEV rules for access to the Crazyradio and NRF bootloader
  • crazyflie-pc-client pre-cloned at latest stable version
  • pyusb
  • UDEV rules to automatically launch the cfheadless client when Crazyradio is plugged in
  • Driver for the Xbox 360 wireless controller and automatic start of the utilities
Creating the SD-card
How to use the SD-card image
First of all you need to set up what controller and link settings you are using. This is done by editing the two files in the folder /home/pi named controller.conf and link.conf. They should only contain one row each.
To fly first insert the USB controller, then power on the Crazyflie and lastly insert the Crazyradio. This will start the cfheadless client and connect to the Crazyflie. In a few seconds you should be ready to fly.
To quit either power off the Crazyflie or pull-out the Crazyradio.
Troubleshooting
FAQ
How do I get the RedOctane Xbox360 controller to work
You will have to edit the /root/bin/xbox file to contain the following to get the RedOctaine xbox360 (1430:f801) controller to work:
#!/bin/sh
if test "$ACTION" = "add"
then
/usr/bin/xboxdrv --device-by-id 1430:f801 --type xbox360 --axismap X2=X1,Y2=Y1,X1=X2,Y1=Y2 &
else
killall -9 xboxdrv
fi
update_on_pi_release
projects/crazyflie/binaries/raspberrypi.txt · Last modified: 2020-05-12 14:26 by kimberly
