Create a file named /etc/rules.d/99-crazyradio.rules and add the following:
crazyflie$ make # Make copter firmware crazyflie$ make V=1 # Make copter firmware and shows the full compilation commands crazyflie$ make CLOAD=1 # make copter firmware to be used with the bootloader crazyflie$ make flash # Flash firmware using openOCD and the jtagKey crazyflie$ make reset # Reset the copter using openOCD crazyflie$ make openocd # Launch openOCD and connect it to the copter (can then be used via the telnet interface and/or GDB)
Variable | Default value | Usage |
CLOAD | 0 | If at 1 the firmware is liked to be used with the bootloader. |
DEBUG | 1 | If at 1 the firmware will be build without optimization and with debug symbol (the firmware is ~70K in debug mode and ~40K optimized). |
CROSS_COMPILE | arm-none-eabi- | Prefix of the cross compilation toolchain to use. Any bare arm GCC should do. The default value is good for the CodeSourcery toolchain. |
OPENOCD_INTERFACE | interface/jtagkey.cfg | JTAG interface configuration file to use with openOCD. Default is for the Amontec JtagKEY. |
V | 0 | Verbose mode. If V=1 the compilers command lines will be displayed. If V=0 only the tool type and target file are displayed. |
It must be noted that the openOCD targets do not make the copter code, hence the compilation must be called first with make
and then make flash
can be called.
