projects:crazyflie:devenv:index
Development environment
Software Tools
Software used
The following software are used by the Crazyflie development environment toolchain:
Setup on Fedora 16
Installing
Setup on Ubuntu 10.04 LTS / 11.10
TBD
Setup on Windows
TBD
Compiling the copter code
crazyflie$ make         # Make copter firmware
crazyflie$ make V=1     # Make copter firmware and shows the full compilation commands
crazyflie$ make CLOAD=1 # make copter firmware to be used with the bootloader
crazyflie$ make cload   # Flash the firmware using the radio bootloader
crazyflie$ make flash   # Flash firmware using openOCD and the jtagKey
crazyflie$ make reset   # Reset the copter using openOCD
crazyflie$ make openocd # Launch openOCD and connect it to the copter (can then be used via the telnet interface and/or GDB)
Variable Default value Usage
CLOAD 0 If at 1 the firmware is liked to be used with the bootloader.
DEBUG 1 If at 1 the firmware will be build without optimization and with debug symbol (the firmware is ~70K in debug mode and ~40K optimized).
CROSS_COMPILE arm-none-eabi- Prefix of the cross compilation toolchain to use. Any bare arm GCC should do. The default value is good for the CodeSourcery toolchain.
OPENOCD_INTERFACE interface/jtagkey.cfg JTAG interface configuration file to use with openOCD. Default is for the Amontec JtagKEY.
V 0 Verbose mode. If V=1 the compilers command lines will be displayed. If V=0 only the tool type and target file are displayed.
PYTHON2 python Name of the Python 2.7 interpreter
Compiling and flashing the bootloader
crazyloader$ make       # Make the bootoader
crazyloader$ make flash # Flash the bootloader with openOCD
projects/crazyflie/devenv/index.1359675204.txt.gz · Last modified: 2015-07-15 16:30 (external edit)
