The CRTP packet consists of 32 bytes of data:
| PORT | DATA |
| PORT | <31 |
1 x
The ports numbers are composed of: Priority, task number and message number. * The priority is set by the 2 MSB of the port number. It permit to each task to chose in a per message basis the priority of its messages * The task number is used by CRTP to distribute the messages to the different tasks in the copter * Finally the message number is composed by the two LSB and permit to have 4 different communication channel per task.
A proposed notation is P:T:N, P is the priority, T is the task number and N the message number. The port number is then built as follow:
+---+---+---+---+---+---+---+---+ | P P | T T T T | N N | +---+---+---+---+---+---+---+---+ #define PORT(P,T,N) ((P<<6) | (T<<2) | N)
'NOTE:' This is currently being changed!
Serial port:
| START | PORT | LENGTH | DATA | CRC |
| 0xAAAA| PORT | <31 | DATA | CRC |
2 1 1 x 1 :byte
==== 2.4 GHz NordicSemi Radio ==== #physical_nordic
Wireless:
| PORT | DATA |
| PORT | <31 |
1 x
The wireless firmware adds ADDRESS, PID, LENGTH and CRC automatically.
| *Port* | *Target* |
| 000 | Console |
| *1* | Acc Log |
| *2* | Gyro Log |
| *3* | IMU Log |
| *4* | MultiLog 1 |
| *5* | MultiLog 2 |
| *6* | PID Settings |
| *7* | Command |
| *8* | Copter information |
| *9* | Parameters |
| *13* | Flight control |
| 0:13:0 | Send/Receive yaw, pith, roll and throttle |
| *15* | Link layer reserved |
| 3:15:0 | Echo (profiling) |
| 3:15:2 | Sink (profiling) |
| 3:15:3 | NULL packet |
#console
This port is used as a simulation of the text based console. The idea is to map putc/getc there (and, by extention, it should be the target of printf).
The packet format contains only the datas to send/receive (this is a bidirectional port): <pre> +——–+
| Data |
1-31 :bytes
</pre>
From the copter side a _fair_ behavior should be to have a buffer and to send a new packet if at least one of the 3 following condition is fullfil: * The output buffer (of 31bytes) is full * A “newline” character has to be send (\n and/or \r) * A flush command as been issued
