projects:crazyflie:firmware:comm_protocol
Overview
CRTP?
Communication
Packet structure
The CRTP packet consists of 32 bytes of data:
| PORT | DATA |
| PORT |  <31 |
    1     x
The ports numbers are composed of: Priority, task number and message number. * The priority is set by the 2 MSB of the port number. It permit to each task to chose in a per message basis the priority of its messages * The task number is used by CRTP to distribute the messages to the different tasks in the copter * Finally the message number is composed by the two LSB and permit to have 4 different communication channel per task.
A proposed notation is P:T:N, P is the priority, T is the task number and N the message number. The port number is then built as follow:
| P   P | T   T   T   T | N   N |
#define PORT(P,T,N) ((P<<6) | (T<<2) | N)
'NOTE:' This is currently being changed!
Physical layers
2.4 GHz NordicSemi Radio
Wireless:
| PORT | DATA |
| PORT |  <31 |
    1     x
The wireless firmware adds ADDRESS, PID, LENGTH and CRC automatically.
USB port
Serial port
Serial port:
| START | PORT | LENGTH | DATA | CRC |
| 0xAAAA| PORT |   <31  | DATA | CRC |
    2      1       1       x      1     :byte
Ports
*Port* *Target*
000 Console
*1* Acc Log
*2* Gyro Log
*3* IMU Log
*4* MultiLog 1
*5* MultiLog 2
*6* PID Settings
*7* Command
*8* Copter information
*9* Parameters
*13* Flight control
0:13:0 Send/Receive yaw, pith, roll and throttle
*15* Link layer reserved
3:15:0 Echo (profiling)
3:15:1 Source (profiling)
3:15:2 Sink (profiling)
3:15:3 NULL packet
Console
#console
This port is used as a simulation of the text based console. The idea is to map putc/getc there (and, by extention, it should be the target of printf).
The packet format contains only the datas to send/receive (this is a bidirectional port): <pre> +——–+
Data
 1-31      :bytes
</pre>
From the copter side a _fair_ behavior should be to have a buffer and to send a new packet if at least one of the 3 following condition is fullfil: * The output buffer (of 31bytes) is full * A “newline” character has to be send (\n and/or \r) * A flush command as been issued
projects/crazyflie/firmware/comm_protocol.1343654364.txt.gz · Last modified: 2015-07-15 16:30 (external edit)
