The CRTP packet consists of 32 bytes of data:
| PORT | DATA |
| PORT | <31 |
1 x
The ports numbers are composed of: Priority, task number and message number. * The priority is set by the 2 MSB of the port number. It permit to each task to chose in a per message basis the priority of its messages * The task number is used by CRTP to distribute the messages to the different tasks in the copter * Finally the message number is composed by the two LSB and permit to have 4 different communication channel per task.
A proposed notation is P:T:N, P is the priority, T is the task number and N the message number. The port number is then built as follow:
+---+---+---+---+---+---+---+---+ | P P | T T T T | N N | +---+---+---+---+---+---+---+---+ #define PORT(P,T,N) ((P<<6) | (T<<2) | N)
NOTE: This is currently being changed!
Wireless:
| PORT | DATA |
| PORT | <31 |
1 x
The wireless firmware adds ADDRESS, PID, LENGTH and CRC automatically.
Serial port:
| START | PORT | LENGTH | DATA | CRC |
| 0xAAAA| PORT | <31 | DATA | CRC |
2 1 1 x 1 :byte
+--------+ | Data | +--------+ 1-31 :bytes
| Port | Function |
| (0,5,0) | TOC access |
| (0,5,1) | Block access |
| (0,5,2) | Logging data |
This port is used to access the loggable variables table of content. The first byte of the message is a message ID, three messages ID are defined:
| 0 | | | | |
| 1 | | | | |
| 3 | Num. Vars | CRC32 |
Bytes 1 1 4
| Port | Function |
| (0,9,0) | TOC access |
| (0,9,1) | Parameter read |
| (0,9,2) | Parameter write |
| 0 | | | | |
| 1 | | | | |
| 3 | Num. Param | CRC32 |
Bytes 1 1 4
