| Port | Function |
| (0,5,0) | TOC access |
| (0,5,1) | Block access |
| (0,5,2) | Logging data |
This port is used to access the loggable variables table of content. The first byte of the message is a message ID, three messages ID are defined:
| 0 | | | | |
| 1 | | | | |
| 3 | Num. Vars | CRC32 |
Bytes 1 1 4
| Port | Function |
| (0,9,0) | TOC access |
| (0,9,1) | Parameter read |
| (0,9,2) | Parameter write |
| 0 | | | | |
| 1 | | | | |
| 3 | Num. Param | CRC32 |
Bytes 1 1 4
