| Port | Channel | Function |
| 5 | 2 | Log data access |
This port is used to access the loggable variables table of content.
7 6 5 4 3 2 1 0 +---+---+---+---+---+---+---+---+ | R | Port | Channel | +---+---+---+---+---+---+---+---+ | Packet length | +---+---+---+---+---+---+---+---+ | DATA 0 | +---+---+---+---+---+---+---+---+ : : : : : : : : : +---+---+---+---+---+---+---+---+ | DATA 30 | +---+---+---+---+---+---+---+---+
Computer Crazyflie
Get TOC CRC32 --->
<--- TOC CRC32
[Compare CRC]
Computer Crazyflie
Get next element --->
<--- TOC element
<--- TOC element
<--- Last TOC element
[Fetch complete]
| 0 | | | | |
| 1 | | | | |
| 3 | Num. Vars | CRC32 |
Bytes 1 1 4
| Port | Function |
| (0,9,0) | TOC access |
| (0,9,1) | Parameter read |
| (0,9,2) | Parameter write |
| 0 | | | | |
| 1 | | | | |
| 3 | Num. Param | CRC32 |
Bytes 1 1 4
| 3:15:0 | Echo (profiling) |
| 3:15:2 | Sink (profiling) |
| 3:15:3 | NULL packet |
