7 6 5 4 3 2 1 0 +---+---+---+---+---+---+---+---+ | 0xAA | +---+---+---+---+---+---+---+---+ | 0xAA | +---+---+---+---+---+---+---+---+ | R | Port | Channel | +---+---+---+---+---+---+---+---+ | Packet length | +---+---+---+---+---+---+---+---+ | DATA 0 | +---+---+---+---+---+---+---+---+ : : : : : : : : : +---+---+---+---+---+---+---+---+ | DATA 30 | +---+---+---+---+---+---+---+---+ | CRC | +---+---+---+---+---+---+---+---+ +-------+-------+-------+-------+ | 0xAA | 0xAA | Header | +-------+-------+-------+-------+
| Port | Channel | Function |
| 5 | 2 | Log data access |
| 1 | Variable ID | |
| 2 | Type (ref to variable type?) | |
| 0 | | | | |
| 1 | | | | |
| 3 | Num. Vars | CRC32 |
Bytes 1 1 4
Computer Crazyflie
Get TOC CRC32 --->
<--- TOC CRC32
[Compare CRC]
Computer Crazyflie
Get next element --->
<--- TOC element
<--- TOC element
<--- Last TOC element
[Fetch complete]
| 1 | Desired block id | |
| 2 | Period | |
| 3-31 | Variables to log | |
| 1 | Block ID | |
| 2-31 | Variables to log | |
| 1 | Block ID | |
| 1 | Block ID | |
| 1 | Block ID |
| Log Type | Description |
| 1 | uint8_t |
| 2 | uint16_t |
| 3 | uint32_t |
| 4 | int8_t |
| 5 | int16_t |
| 6 | int32_t |
| 7 | float32 |
| 8 | float16 |
| 0 | Variable in TOC |
| Error | Description |
| 0x00 | No error |
| 0x01 | Block not found |
| 0xFF | Generic error |
Computer Crazyflie
Add log packet --->
<--- Log packet added ok
[DONE]
Packet structure:
Computer Crazyflie
Delete log packet --->
<--- Log packet deleted ok
[DONE]
Packet structure:
| Port | Function |
| (0,9,0) | TOC access |
| (0,9,1) | Parameter read |
| (0,9,2) | Parameter write |
| 0 | | | | |
| 1 | | | | |
| 3 | Num. Param | CRC32 |
Bytes 1 1 4
| 3:15:0 | Echo (profiling) |
| 3:15:2 | Sink (profiling) |
| 3:15:3 | NULL packet |
