projects:crazyflie:firmware:comm_protocol
Overview
CRTP
Communication
Packet structure
  7   6   5   4   3   2   1   0
|     Port      |  Res. | Chan. |
|            DATA 30            |
|  0xAA  |  0xAA  | Header | Length | Data0  | Packet | CRC32  |
Field Byte Bit Description
Header 0 0-1 The destination channel
0 2-3 Reserved for transport layer
0 4-7 The destination port
Data 1-31 The data in the packet
Physical layers
2.4 GHz NordicSemi Radio
USB port
Serial port
  7   6   5   4   3   2   1   0
| R |     Port      |  Channel  |
|            DATA 30            |
|              CRC              |
Header 2 0-2 The destination channel
2 3-6 The destination port
2 7 Resend flag. If R=1 the last packet needs to be resent
Size 3 The size of the packet
Data 4-34 The data in the packet
CRC 35-36 The CRC16 of the packet
Ports
Port Target
0 Console
5 Logging
9 Parameters
13 Flight control
15 Link layer
Console
  7   6   5   4   3   2   1   0
|             CHAR 0            |
|             CHAR 30           |
|  0xAA  |  0xAA  | Header | Length | Data0  |        | Data30 |
  • The output buffer (of 31 bytes) is full
  • A “newline” character has to be send (\n and/or \r)
  • A flush command as been issued
Logging
Table of content access
Messages
Request for Byte Description
TOC item 0 0x00 to identify the command
1 The index of the TOC item to request. This is optional, if the index is omitted the first item of the TOC will be returned
TOC CRC and count 0 Request the TOC CRC and item count
Reply for Byte Description
1 The ID of the next variable to fetch. If ID == 0xFF no more items are available.
2 Variable ID
3 Type (ref to variable type?)
4-n Null terminated string containing group name
n-m Null terminated string containing variable name
TOC CRC and count 0 0x01 to identify the command
1 Number of total variables in TOC
2-5 CRC32 value of the TOC (of what exacly? group/names?)
Usage
   Computer                 Crazyflie
Get TOC CRC32      --->
                   <---     TOC CRC32
[Compare CRC]
   Computer                 Crazyflie
Request for TOC item --->
with ID omitted
                     <---  First TOC element (including ID of next element)
[Fetch complete]
Log settings access
Messages
Adding a new log 0 0x00 for identifying the command to add a logging block
1 Desired block id
2 Period in 10th of ms
3-31 Variables to log
Append to log 0 0x01 for identifying the command to append logging variables to an existing block
1 Block ID
2-31 Variables to log
Delete a log 0 0x02 to identify the command for delete an existing block
1 Block ID
Enable a log 0 0x03 to identify the command for enabling logging data from an existing block
1 Block ID
Disable a log 0 0x04 to identify the command for disablling logging data from an existing block
1 Block ID
Byte Description
0 The command byte that was sent
1 The ID of the log block that the command operated on
2 Return status for the command. If != 0 see list of return codes
Variable format
Log Type Description
1 uint8_t
2 uint16_t
3 uint32_t
4 int8_t
5 int16_t
6 int32_t
7 float32
8 float16
Storage Type Description
0 Variable in TOC
1 Memory address pointing to uint8_t
2 Memory address pointing to uint16_t
3 Memory address pointing to uint32_t
4 Memory address pointing to int8_t
5 Memory address pointing to int16_t
6 Memory address pointing to int32_t
7 Memory address pointing to float32
  7   6   5   4   3   2   1   0
|    Log type   | Storage type  |
|        Variable ID            |
  7   6   5   4   3   2   1   0
|        Mem Address 0          |
|        Mem Address 1          |
|        Mem Address 2          |
|        Mem Address 3          |
List of return codes
Error Description
0x00 No error
0x01 Block not found
0x02 Block already created, needs delete
0xFF Generic error
Usage
   Computer                 Crazyflie
Add log packet     --->
                   <---     Log packet added ok
[DONE]
Packet structure:
   Computer                 Crazyflie
Delete log packet  --->
                   <---     Log packet deleted ok
[DONE]
Packet structure:
Log data access
Adding a log block logging variable ID 0x55 at 100ms interval and of type uint16:
Receiving a log block logging variable (value 0xBABE):
CF -> Computer : 0x[5,2] 0x55 0xBA 0xBE
Parameters
Port Function
(0,9,0) TOC access
(0,9,1) Parameter read
(0,9,2) Parameter write
TOC access
Message ID Meaning in upstream packets Meaning in downstream packets
0 Reset TOC pointer Last TOC element
1 Get next TOC element TOC element
3 Get TOC CRC32 TOC CRC32
Bytes     1       1          1    Null terminated strings
        | 0 |            |      |          |              |
        +---+  Param ID  | Type |  Group   |     Name     |
        | 1 |            |      |          |              |
        | 3 | Num. Param |  CRC32   |
Bytes     1       1           4
Parameter read
Parameter write
Fight control
3:15:0 Echo (profiling)
3:15:1 Source (profiling)
3:15:2 Sink (profiling)
3:15:3 NULL packet
projects/crazyflie/firmware/comm_protocol.1348659982.txt.gz · Last modified: 2015-07-15 16:30 (external edit)
