Each variable to log is contained in a
| Port | Channel | Function |
| 5 | 2 | Log data access |
Request (PC to Copter):
| GET_ITEM (0) | Element ID |
Length 1 1
Answer (Copter to PC):
| GET_ITEM (0) | Element ID | Type | Group | Name |
| Request fields | Content |
| GET_ITEM | At 0 for GET_ITEM operation |
| Element ID | ID of the element to be retrieved. The variables are numbered from 0 to LOG_LEN (see GET_INFO command) |
| Answer fields | Content |
| GET_ITEM | 0 for GET_ITEM operation |
| Element ID | ID of the element returned |
