| Port | Channel | Function |
| 5 | 1 | Log control |
| 5 | 2 | Log data |
Request (PC to Copter):
| GET_ITEM (0) | ID |
Length 1 1
Answer (Copter to PC):
| Request fields | Content |
| GET_ITEM | At 0 for GET_ITEM operation |
| ID | ID of the item to be retrieved. The variables are numbered from 0 to LOG_LEN (see GET_INFO command) |
| Answer fields | Content |
| GET_ITEM | 0 for GET_ITEM operation |
| ID | ID of the item returned |
| GET_INFO (1) |
Length 1
Length 1 1 4 1 1
| GET_INFO | At 1 for GET_INFO operation |
| GET_INFO | 1 for GET_INFO operation |
| LOG_LEN | Number of log items contained in the log table of content |
| LOG_CRC | CRC values of the log TOC memory content. This is a fingerprint of the copter build that can be used to cache the TOC |
| LOG_MAX_PACKET | Maximum number of log packets that can be programmed in the copter |
| LOG_MAX_OPS | Maximum number of operation programmable in the copter. An operation is one log variable retrieval programming |
| Control command byte | Command | Operation |
| 0 | CREATE_BLOCK | Create a new log block |
| 1 | APPEND_BLOCK | Append variables to an existing block |
| 2 | DEL_BLOCK | Delete log block |
| 3 | START_BLOCK | Enable log block transmition |
| 4 | STOP_BLOCK | Disable log block transmition |
