projects:crazyflie:hardware:explained
Crazyflie KIT electonics explained
Electronics overview
Battery
PCM
Item Specification
Overcharge detection voltage 4.20±0.025V
Overcharge release voltage 4.10±0.050V
Overcharge detection delay time 0.92~1.38S
Over discharge detection voltage 2.80±0.050V
Over discharge release voltage 2.90±0.100V
Over discharge detection delay time 115~173 ms
Over discharge current 4~9A
Over discharge current delay time 7.2~11ms
Short detection delay time 220~380us
Short release condition Cut of load
Current consumption Max 0.7uA
Suggested max continuous charge/discharge current 3A
Suggested operation temp -20 - +60 deg C
Internal resistance <60mOhm
LiPo
Specification:
Model Voltage (V) Capacity (mAH) Thickness (±0.2) Width (±0.5) Height (±0.5) Weight (g) Charge Rate Continues Discharge Rate Burst (≤5S)
671723HS25C 3.7 170 6.9 17 23 3.9 1C-5C 25C (≥ 80%) 50C
Connector
Replacing
Power management
MCU
Sensors
Expansion header
2.4GHz radio
Motor drivers
Motors
projects/crazyflie/hardware/explained.1354546363.txt.gz · Last modified: 2015-07-15 16:30 (external edit)
