Item | Specification | ||
Overcharge detection voltage | 4.20±0.025V | ||
Overcharge release voltage | 4.10±0.050V | ||
Overcharge detection delay time | 0.92~1.38S | ||
Over discharge detection voltage | 2.80±0.050V | ||
Over discharge release voltage | 2.90±0.100V | ||
Over discharge detection delay time | 115~173 ms | ||
Over discharge current | 4~9A | ||
Over discharge current delay time | 7.2~11ms | ||
Short detection delay time | 220~380us | ||
Short release condition | Cut of load | ||
Current consumption | Max 0.7uA | ||
Suggested max continuous charge/discharge current | 3A | ||
Suggested operation temp | -20 - +60 deg C | ||
Internal resistance | <60mOhm |
Specification:
Model | Voltage (V) | Capacity (mAH) | Thickness (±0.2) | Width (±0.5) | Height (±0.5) | Weight (g) | Charge Rate | Continues Discharge Rate | Burst (≤5S) | ||||||||||
671723HS25C | 3.7 | 170 | 6.9 | 17 | 23 | 3.9 | 1C-5C | 25C (≥ 80%) | 50C |
