Item | Specification | ||
Overcharge detection voltage | 4.20±0.025V | ||
Overcharge release voltage | 4.10±0.050V | ||
Overcharge detection delay time | 0.92~1.38S | ||
Over discharge detection voltage | 2.80±0.050V | ||
Over discharge release voltage | 2.90±0.100V | ||
Over discharge detection delay time | 115~173 ms | ||
Over discharge current | 4~9A | ||
Over discharge current delay time | 7.2~11ms | ||
Short detection delay time | 220~380us | ||
Short release condition | Cut of load | ||
Current consumption | Max 0.7uA | ||
Suggested max continuous charge/discharge current | 3A | ||
Suggested operation temp | -20 - +60 deg C | ||
Internal resistance | <60mOhm |
Specification:
Model | Voltage (V) | Capacity (mAH) | Thickness (±0.2) | Width (±0.5) | Height (±0.5) | Weight (g) | Charge Rate | Continues Discharge Rate | Burst (≤5S) | ||||||||||
671723HS25C | 3.7 | 170 | 6.9 | 17 | 23 | 3.9 | 1C-5C | 25C (≥ 80%) | 50C |
The expansion header is located on the left side of the Crazyflie. It is a 10×2 pin 1.27mm (0.05“) pitch trough-hole footprint which comes unmounted. The idea with the through-hole is that it makes it possible to mount expansion boards on either or both sides. It would even be possible to stack several on top of each other.
Header pin description
Pin nr | Name | Description | |||
1 | VCC | Digital supply voltage | |||
2 | TMS | Test Mode Select | |||
3 | EXT_I2C_SCL/TX | I2C clock or UART TX | |||
4 | TCK | Test Clock | |||
5 | EXT_I2C_SDA/RX | I2C data or UART RX | |||
6 | TDO | Test Data Out | |||
7 | N/A | Could be used for keying | |||
8 | TDI | Test Data In | |||
9 | DGND | Digital ground | |||
10 | SNRST | System reset | |||
11 | EXT_SPI_CS/AIN4 | SPI chip select or analogue in 4 | |||
12 | EXT_SPI_MOSI/AIN5 | SPI Master Out Slave In chip or analogue in 5 | |||
13 | EXT_SPI_SCK/AIN6 | SPI clock or analogue in 6 | |||
14 | EXT_SPI_MISO/AIN7 | SPI Master In Slave Out chip or analogue in 7 | |||
15 | VCC | Digital supply voltage | |||
16 | VCOM | Battery/USB voltage | |||
17 | DGND | Digital ground | |||
18 | DGND | Digital ground | |||
19 | AGND | Analogue ground | |||
20 | VCCA | Analogue supply |
The motor driver, as we use brushed motors, is a simple pull down mosfet as shown in the schematics. There is also a free-wheel diode to take the Back-EMF spikes generated by the motor during PWM-ing.
The mosfet we choose is the PMV31XN in a SOT-23 package. It can handle a lot of power and should be good for at least 3A each. The most important property of the mosfet though might be the on resistance (Rdson) since it effects the amount of power the motors can make use of. We measured the PMV31XN Rdson at 2.8V and 0.8A to be ~40 mOhm
