This page has details about how to assemble the Crazyflie Micro Quadcopter Kit.
What's in the packet
  • Crazyflie control board
  • 4 x motor mounts
  • 5 x coreless motors
  • 4 x CW propellers
  • 4 x CCW propellers
  • 1 LiPo battery
Tools you need
  • Soldering iron
  • Glue (preferably hot glue)
What do you need to do
TODO: Insert images here
  2. Insert the motors into the motor mounts and twist the two wires together so they are easier to handle
  3. Put some solder on the motor pads on the front side of the PCB
  4. Attach the copter so it's standing on edge
  5. Heat the front side PCB pad with the soldering iron and insert the motor wire with the tweezers from the back side. Do the same for all the motors (see drawings blow for mapping)
  6. Put some glue on the tips of the wings and insert the motor mounts
  7. Attach the propellers (see drawings blow for mapping)
Video
TODO:
Motors and propellers
projects/crazyflie/mechanics/assembly.1358326250.txt.gz · Last modified: 2015-07-15 16:30 (external edit)
