This page has details about how to assemble the Crazyflie Micro Quadcopter Kit.
What's in the packet
Crazyflie control board
4 x motor mounts (3D laser sintered nylon plastic)
5 x coreless motors (one is as spare)
4 x CW propellers
4 x CCW propellers
1 LiPo battery
Tools you need
Soldering iron
Glue (preferably hot glue)
Tweezers and a clamp or third-hand recommended
What do you need to do
TODO: Insert images here
Check that you have everything that's needed
Insert the motors into the motor mounts and twist the two wires together so they are easier to handle
Put some solder on the motor pads on the front side of the PCB
Attach the copter so it's standing on edge
Heat the front side PCB pad with the soldering iron and insert the motor wire with the tweezers from the back side. Do the same for all the motors (see drawings blow for mapping)
Put some glue on the tips of the wings and insert the motor mounts
Attach the propellers (see drawings blow for mapping)
Video
Motors and propellers
projects/crazyflie/mechanics/assembly.1359807958.txt.gz · Last modified: 2015-07-15 16:30 (external edit)
