What's in the packet
  • Crazyflie control board
  • 5 x CW propellers
  • 5 x CCW propellers
  • 1 LiPo battery
Tools you need
  • Soldering iron and solder
  • Scissors
What do you need to do
TODO: Insert images here
  3. Slip the twisted motor wires through the motor mount arm section. I can be a bit tricky so have patience.
  5. Press the motor mount on to the PCB arm. Start with M1.
  7. Turn the PCB around carefully not removing the wire from the hole and solder it from the top of the PCB.
  9. Attach the propellers (see drawings blow for mapping). We recommend you sorting out the best propellers. See maximizing performance
  10. Attached the battery and try to centre the weight on the PCB as good as you can.
  11. Power on and check that all motors spin correctly during start-up.
Video
Motors and propellers
Maximizing performance
Balancing propellers
Vibration is one of the biggest reasons the Crazyflie performance is degraded. Vibration effect the gyro and accelerometer measurements making them more noisy and inaccurate. Vibration is mainly caused by unbalanced propellers but can be caused by a bent motor axis as well. Balancing these small propellers is extremely hard and we are still searching for a good way to do it. An easier way to get we balanced propellers are to sort them and categorize their vibration. This can easily be done by using the spare motor and a normal 1.5V AA battery to power it while testing each propeller. After this has been done use the propellers with the least vibrations.
Centre the battery weight
projects/crazyflie/mechanics/assembly.1366633122.txt.gz · Last modified: 2015-07-15 16:30 (external edit)
