What's in the packet
  • Crazyflie control board
  • 5 x CW propellers
  • 5 x CCW propellers
  • 1 LiPo battery
Tools you need
  • Soldering iron and solder
  • Scissors
What do you need to do
TODO: Insert images here
  3. Slip the twisted motor wires through the motor mount arm section. I can be a bit tricky so have patience.
  5. Press the motor mount on to the PCB arm. Start with M1.
  7. Turn the PCB around carefully not removing the wire from the hole and solder it from the top of the PCB.
  9. Attach the propellers (see drawings blow for mapping). We recommend you sorting out the best propellers. See maximizing performance
  10. Attached the battery and try to centre the weight on the PCB as good as you can.
  11. Power on and check that all motors spin correctly during start-up.
Video
Motors and propellers
Maximizing performance
Balancing propellers
Centre the battery weight
projects/crazyflie/mechanics/assembly.1366633418.txt.gz · Last modified: 2015-07-15 16:30 (external edit)
