What's in the packet
  • Crazyflie control board
  • 5 x CW propellers
  • 5 x CCW propellers
  • 1 LiPo battery
Tools you need
  • Soldering iron and solder
  • Scissors
What do you need to do
7. Turn the PCB around carefully not removing the wire from the hole and solder it from the top of the PCB.
11. Before you power it on visually inspect your soldering for shorts. After that power on and check that all motors spin during start-up and in the right direction.
Video
Motors and propellers
Maximizing performance
Balancing propellers
Centre the battery weight
projects/crazyflie/mechanics/assembly.1366831680.txt.gz · Last modified: 2015-07-15 16:30 (external edit)
