What's in the packet
  • Crazyflie control board
  • 5 x CW propellers
  • 5 x CCW propellers
  • 1 LiPo battery
Tools you need
  • Soldering iron and solder
  • Scissors
Check the electronics
What do you need to do
9. Attach the propellers (see drawings below for mapping). Your clock-wise propellers may be labeled with an “A”, otherwise look at the curvature of the tips to determine which is CW and which is CCW. The dull surface goes up, the shiny surface goes down. You will also see a small molded ring on the top surface. We recommend you sorting out the best propellers. See maximizing performance
Video
Motors and propellers
projects/crazyflie/mechanics/assembly.1369400196.txt.gz · Last modified: 2015-07-15 16:30 (external edit)
