All command line tools used the same link diver model. The link driver to use in order to communicate with the copter is chosen with the -l
command line argument. Also the tools accepts the -h
argument that will display help about the link driver as well as the default driver used if none is provided:
The available drivers are:
crazyload.py permits to update the copter firmware using the Crazyload radio bootloader. This is a self-documented command line tool (launch python crazyload.py -h
