projects:crazyflie:pc_utils:index
Crazyflie PC utilities
Common install instructions
Graphical User Interface
Install instructions
Using the GUI
Command line tools
crazyclient$ python gamepadCtrl.py -h
CRTP Driver loader options:
 -l <driver_uri> : Load the link driver with the requested URI
 -h              : Print this help message
Unless otherwise specified the URI "radio://0" will be used
The available drivers are:
  • radio://n[/channel[/speed]] Radio dongle number 'n' (many can be connected to the computer) communicating on a specified channel with a specified speed. The speed and channel are optional, default channel is 2 and default speed is 2M. The speed can be 2M, 1M or 250K. For example:
    • radio://0 uses radio dongle 0 to communicate on channel 2 at 2Mbit/sec
    • radio://0/77 uses radio dongle 0 to communicate on channel 77 at 2Mbit/sec
    • radio://0/77/250K uses radio dongle 0 to communicates on channel 77 at 250Kbit/sec
  • loop:// Loopback driver. Mainly aims at testing tools without having them to crash because of the missing radio link |
gamepadCtrl.py
Control Gamepad Key/axis
Pitch LY
Roll LX
Thrust RY
Yaw rate RX
Emergency stop Ps button
crazyload.py
getinfo.py
crazyclient$ sudo python getinfo.py -l radio://0/77
Detected CrazyRadio dongle version 0.32
Channel 77
Data rate 2M
CPU ID: 52:ff:70:06:48:89:49:53:15:31:10:87
Battery voltage: 3.764599V
CrazyCopter version: 0.9.0
Copter class name: CrazyFlie
crazyclient$
projects/crazyflie/pc_utils/index.1331630436.txt.gz · Last modified: 2015-07-15 16:30 (external edit)
