sudo yum install pygame pyusb PyQt4 PyQwt
The following has been tested on Ubuntu 10.04 and 11.10. Note that this will pull in a lot of dependencies.
Needs to be written
The available drivers are:
| Pitch | LY |
| Roll | LX |
| Thrust | RY |
| Yaw rate | RX |
