The following has been tested on Ubuntu 10.04 and 11.10. Note that this will pull in a lot of dependencies.
Only tested on Windows XP.
The following has to be downloaded/installed for the PC utilities to work on windows:
The available drivers are:
| Pitch | LY |
| Roll | LX |
| Thrust | RY |
| Yaw rate | RX |
