projects:crazyflie:pc_utils:index
Crazyflie PC utilities
Install instructions
  • Python 2.7
  • pyGame
  • PyUSB (0.X or 1.X)
  • libusb
  • Python bindings for Qt4
Installing on Fedora
Installing on Ubuntu
The following has been tested on Ubuntu 10.04 and 11.10. Note that this will pull in a lot of dependencies.
Fix udev premissions on Linux
sudo groupadd plugdev
Installing on Windows XP/7
Only tested on Windows XP.
The following has to be downloaded/installed for the PC utilities to work on windows:
Graphical User Interface
Command line tools
crazyclient$ python gamepadCtrl.py -h
CRTP Driver loader options:
 -l <driver_uri> : Load the link driver with the requested URI
 -h              : Print this help message
Unless otherwise specified the URI "radio://0" will be used
The available drivers are:
  • radio://n[/channel[/speed]] Radio dongle number 'n' (many can be connected to the computer) communicating on a specified channel with a specified speed. The speed and channel are optional, default channel is 2 and default speed is 2M. The speed can be 2M, 1M or 250K. For example:
    • radio://0 uses radio dongle 0 to communicate on channel 2 at 2Mbit/sec
    • radio://0/77 uses radio dongle 0 to communicate on channel 77 at 2Mbit/sec
    • radio://0/77/250K uses radio dongle 0 to communicates on channel 77 at 250Kbit/sec
  • loop:// Loopback driver. Mainly aims at testing tools without having them to crash because of the missing radio link |
crazyload.py
$ make cload
  #or ...
$ python crazyload.py flash cflie.bin
Restart the CrazyFlie you want to bootload in the next 10 seconds ...
Connection established!
Flash pages: 128 | Page size: 1024 | Buffer pages: 10 | Start page: 10
118 KBytes of flash avaliable for firmware image.
Flashing 43907 bytes (43 pages) ..........10..........10..........10..........10...3
Reset in firmware mode ...
Done!
Here cflie.bin is the binary file of the firmware to be flashed. After launching this command the copter has to be restarted and the flash procedure will start. When the flash procedure is finished the copter will boot the new firmware
getinfo.py
crazyclient$ sudo python getinfo.py -l radio://0/77
Detected CrazyRadio dongle version 0.32
Channel 77
Data rate 2M
CPU ID: 52:ff:70:06:48:89:49:53:15:31:10:87
Battery voltage: 3.764599V
CrazyCopter version: 0.9.0
Copter class name: CrazyFlie
crazyclient$
projects/crazyflie/pc_utils/index.1347912508.txt.gz · Last modified: 2015-07-15 16:30 (external edit)
