. sudo apt-get install python2.7 python-usb python-pygame python-qt4
Only tested on Windows XP.
The following has to be downloaded/installed for the PC utilities to work on windows:
The available drivers are:
$ make cload #or ... $ python crazyload.py flash cflie.bin Restart the CrazyFlie you want to bootload in the next 10 seconds ... Connection established! Flash pages: 128 | Page size: 1024 | Buffer pages: 10 | Start page: 10 118 KBytes of flash avaliable for firmware image. Flashing 43907 bytes (43 pages) ..........10..........10..........10..........10...3 Reset in firmware mode ... Done! $
Here cflie.bin is the binary file of the firmware to be flashed. After launching this command the copter has to be restarted and the flash procedure will start. When the flash procedure is finished the copter will boot the new firmware
