The Crazyflie PC utilities are developed using Python 2.7. The Crazyflie library is used from the command line tools as well as a graphical user interface. For install instructions of PC side software please see this page.
The Crazyflie library can be used to easily integrate control and communication with the Crazyflie quadcopter into an application. Currently the only implementation is done in Python and can be found here.
The available drivers are:
$ make cload #or ... $ python crazyload.py flash cflie.bin Restart the CrazyFlie you want to bootload in the next 10 seconds ... Connection established! Flash pages: 128 | Page size: 1024 | Buffer pages: 10 | Start page: 10 118 KBytes of flash avaliable for firmware image. Flashing 43907 bytes (43 pages) ..........10..........10..........10..........10...3 Reset in firmware mode ... Done! $
Here cflie.bin is the binary file of the firmware to be flashed. After launching this command the copter has to be restarted and the flash procedure will start. When the flash procedure is finished the copter will boot the new firmware
