Please note In the 2013.4.1 and previous versions there's a bug where the loading of a previous configuration will not work correctly. The values are not loaded but the configuration call still be saved. This results in a configuration file that will not work and an error will be shown when trying to use it. In order to fix this manually delete the contents of the user config folder (win: C:\Users\your_user\AppData\Roaming\cfclient, linux: ~/.config/cfclient) and create a new configuration from scratch as described above.
| Controller | Linux | Windows XP | Windows 7 32bit | Windows 7 64bit | Mac OSX |
| Playstation 3 (or copy) | Tested Ok | Tested Ok | MotionJoy gives wrong mappings | Motion Joy gives wrong mappings | Not tested |
