| Controller | Linux | Windows XP | Windows 7 32bit | Windows 7 64bit | Mac OSX |
| Playstation 3 (or copy) | Tested Ok | Tested Ok | MotionJoy gives wrong mappings | Motion Joy gives wrong mappings | Not tested |
