projects:crazyflie:pc_utils:inputdevices
Limitations
  • After entering the configuration dialogue the application needs to be restarted.
  • There's only support for one input device. If you have multiple connected the application will choose the first one.
Steps to get the controller working
  • The input-device needs to be recognized by the host operating system. This means that it should be seen in the operating system and be usable in other applications or utilities.
  • When using the Crazyflie graphical control client you need at least the correct mappings for roll/pitch/yaw/thrust. This can be checked by opening the Flight Data tab. If the input-device is found and opened then you should see values in the Target fields for Roll,Pitch,Yaw and Thrust. Moving the analogue axis should show you output here. Make sure that you get the full span according to the settings on the left side of the tab. I.e if the setting for Max roll/pitch is 20 then you should be able to get from -20 to + 20 in the target field (and the same for yaw and thrust). Also make sure that none of the axis interact (like moving roll will also move pitch).
  • If the mappings are not correct in the previous point go to the menu Input-device→Configure device mapping, select the device you would like to configure and go though the configuration by clicking detect on each of the items in the dialog (everything has to be configured). Lastly enter the name of the configuration (without file extension) and press save. Now restart the application and try again.
"Out-of-the-box" support for controllers/operating systems
Controller Linux Windows XP Windows 7 32bit Windows 7 64bit Mac OSX
Playstation 3 (or copy) Tested Ok Tested Ok MotionJoy gives wrong mappings Motion Joy gives wrong mappings Not tested
Xbox 360 (or copy) Tested Ok Tested Ok Tested Ok Tested Ok Not tested
Installation of Playstation 3 controller
Linux
With USB
Just plug it in and it will work out of the box :-)
With Bluetooth
Windows XP
With USB
With Bluetooth
Windows Vista/7 32/64-bit
With USB
With Bluetooth
Mac OSX
With USB
Just plug it in. If it doesn't work immediately press the PS button.
With Bluetooth
projects/crazyflie/pc_utils/inputdevices.1368092464.txt.gz · Last modified: 2015-07-15 16:30 (external edit)
