projects:crazyflie:pc_utils:inputdevices
Limitations
  • After entering the configuration dialogue the application needs to be restarted. Fixed in 2013.4.2
  • There's only support for one input device. If you have multiple connected the application will choose the first one. Fixed in 2013.4.1
Steps to get the controller working
  • The input-device needs to be recognized by the host operating system. This means that it should be seen in the operating system and be usable in other applications or utilities.
  • When using the Crazyflie graphical control client you need at least the correct mappings for roll/pitch/yaw/thrust. This can be checked by opening the Flight Data tab. If the input-device is found and opened then you should see values in the Target fields for Roll,Pitch,Yaw and Thrust. Moving the analogue axis should show you output here. Make sure that you get the full span according to the settings on the left side of the tab. I.e if the setting for Max roll/pitch is 20 then you should be able to get from -20 to + 20 in the target field (and the same for yaw and thrust). Also make sure that none of the axis interact (like moving roll will also move pitch).
  • If the mappings are not correct in the previous point go to the menu Input-device→Configure device mapping, select the device you would like to configure and go though the configuration by clicking detect on each of the items in the dialog (everything has to be configured). Lastly enter the name of the configuration (without file extension) and press save. Now restart the application and try again.
Input device overview
Controller Linux USB Linux BT Win XP USB Win XP BT Win7 USB Win7 BT Mac OSX USB Mac OSX BT
Playstation 3 (or copy) Works Instructions? Works Instructions? Motion joy instructions? Motion joy instructions? Works Instructions
Xbox 360 (or copy) Instructions? N/A Works N/A Works N/A Not tested Not tested
Linux using Bluetooth
WinXP using Bluetooth
Win7 using USB
Video on how to get started with MotionJoy.
Win7 using Bluetooth
Mac OSX with Bluetooth
Xbox 360 controller
Linux using USB
projects/crazyflie/pc_utils/inputdevices.1369395216.txt.gz · Last modified: 2015-07-15 16:30 (external edit)
