| Controller | Linux USB | Linux BT | Win XP USB | Win XP BT | Win7 USB | Win7 BT | Mac OSX USB | Mac OSX BT |
| Playstation 3 (or copy) | Works | Instructions? | Works | Instructions? | Motion joy instructions? | Motion joy instructions? | Works | Instructions |
If you are having problems getting this to work (or you are using the wireless version) then the userspace driver xboxdrv might be needed. It can be installed (on Ubuntu) by running:
sudo apt-get install xboxdrv
And then started by running:
sudo xboxdrv
The ESKY ET6I Remote Control is compatible to the Crazyflie as they share the same radio chipset. In order to use the RC instead of the Crazyflie PC Client, you'll have to compile the firmware with ESKYLINK support. You can do this in the VM, just open a terminal and issue the following commands:
cd ~/projects/crazyflie-firmware make clean && make USE_ESKYLINK=1 CLOAD=1 all
This will create a new firmware file cflie.bin that you can flash to your Crazyflie via the Bootloader in the PC client.
You'll have to make some adjustments on your RC in order for this to work. First, take a look into the battery compartment of your RC. There you'll see two switches. Make sure switch 1 is set to on and switch 2 is set to off (this disables the channel mixing the RC normally applies in order to work with the helicopter models it came bundled with):
Then close the battery compartment again and take a look at the lower right front of your RC. There are four switches, one each for AILeron, ELEvator, THRottle and RUDder. You'll have to adjust these, depending on your RC's Mode. If you have a Mode 1 RC (throttle and rudder on the right stick) the correct setting is AIL-up, ELE-down, THR-up, RUD-down. If on the other hand you have a Mode 2 RC (throttle + rudder on the left stick) you'll need to set those switches to AIL-down, ELE-up, THR-down, RUD-up.
If you want a bit more pep to your RC controlled Crazyflie1) you might want to take a look at the adjustments ''jodell'' made and use his repository version to compile your firmware instead.
