| Controller | Linux USB | Linux BT | Win XP USB | Win XP BT | Win7 USB | Win7 BT | Mac OSX USB | Mac OSX BT |
| Playstation 3 (or copy) | Works | Instructions | Works | Instructions? | Motion joy instructions? | Motion joy instructions? | Works | Instructions |
How to set up Sixaxis on Ubuntu (tested on Ubuntu 13.10)
If you are having problems getting this to work (or you are using the wireless version) then the userspace driver xboxdrv might be needed. It can be installed (on Ubuntu) by running:
sudo apt-get install xboxdrv
And then started by running:
sudo xboxdrv
